AKG solidtube power supply help
georgerarnold
Member
Hello,
I hope someone will be able to help me here.
A friend of mine has an AKG solid tube microphone and the power supply is blowing fuses.
I opened it up and see two varistors have completely blown up.
I’d like to replace them and see if that solves the problem.
I have the schematic but honestly I can’t make head nor tail of it.
I was wondering if somebody might be able to tell me what the parts are that I’m looking for.
I will attach a photo of where they are on the board and the schematic.
Apologies in advance if this is a silly idea.
Hi, I have highlighted the varistors for you.
I would definitely test the mains transformer for function, if I remember correctly then this power supply is notorious for problems with the transformer (due to overload?). I'll have to check this again in my documents.
@georgerarnold
Hi georgerarnold and greetings from Greece.
As you can see by the attached AKG Solidtube 2800z0001 Service Manual they were 2 versions (old – new) for the AKG Solidtube P.S.U. so, it will be smart for you to check it out which one P.S.U. version is the P.S.U. version that your friend’s AKG Solidtube microphone have…
Mine AKG Solidtube microphone with the old version P.S.U. still goes strong after all these years of usage, so I have only good words to say about it, but I understand that the newer version of the AKG Solidtube P.S.U. maybe tends to be more notorious for problems with the power transformer, so it will be a good point of view to check the P.T. if they are any issues there…
  • AKG Solidtube 2800z0001 Service Manual.pdf
    411.8 KB
I had a SolidTube in for repair as few years back with a similar sort of issue. The problem was the mains transformer was blown. If you do a bit of Google research this is a common issue with these mics.
You should definitely check the (blue I think) varistors, but in the case I had they were ok. The varistors normally crack open when they're fried.
