Forssell JMP-1 project.
babyhead
Loas Angeles
Greetings All-
I am thinking about racking one of these:
http://www.forsselltech.com/JMP-1.htm
And using one of these to balance the output...even though it is an input transformer...
http://www.jensen-transformers.com/datashts/11ssp6m.pdf
Which I already have. (2 for $50 on evilBay!)
If I run this transformer in series, can I get 2 isolated 1:1 outputs?
I need this preamp to work driving unknown loads...
I don't see mounting holes or headers on the PCB...is there a trick?
I want to use it mostly as mic amp for a Shure VHF wireless mic with a split. I think it might just rock.
-Mark
Do you mean use the seperate windings in the same transformer...as two seperate transformers?
you can not do that. the windings are all wrapped around eachother and one signal would interfere with another. you will have to use both transformers. one for each channel.
"Do you mean use the seperate windings in the same transformer...as two seperate transformers? "
No...more like the way an api 312 o/p trannie splits the signal to the meter...
Mono source to 2 coupled outputs... or should I use a friggin' Y-cable?!?
-Mark
you could try running it at 150:150+150
just run the primary in parallel and take one signal from one of the secondaries and another signal from the other secondary.
I doný know if the Forssell mic preamp can drive a 150ohms winding, so you can also try the primary in series for 600ohms and take two 150 ohms signals from the secondaries, and live with a 6dB gain loss. I really think that´s the best option. You will not load the output really hard and you have two nice low impedance outputs. That´s 600:150+150.
You do not need two transformers for two outputs. save the other transformer for another channel. This way you will have a two channel mic pre with four transformer coupled outputs.
As this is a transformerless mic pre, intended to be very transparent, I would also include a transformerless cap-coupled output as an option, so you can use that when you don´t want iron sound.
Yes, yes...600:150+150. Input, output, what's the difference? (at least in this case...)
What is a repeat coil, anyway?
If I can figure out how to mount it, it may be my best friend on my next tour...
That and a pair of 1272s for the singer's in-ear mix! A little front-end for a PSM-600. I have an extra -24v rail in this box and I am debating on either a 3rd 1272 or the Forssell, leaning to the Forssell...
Decisions decisions...
JMP-1 is not rated for 600 ohm loads. Maybe it will... ask Fred.
If it will: it makes twice the maximum level that the JT-11SSP-6M can take with low bass distortion.
Be very clear: are you talking ONE amp and ONE transformer? Or TWO transformers?
How isolated?
If you just want to break ground, yes you can get two floating outputs with one transformer but at half the voltage. Maybe full voltage IF the JMP can drive 150 ohms, which looks doubtful. Or full voltage with two transformers, IF the JMP will feed 300 ohms, which is dubious.
If you need to accept a short on one output while still getting "unblemished" signal at the other output: you aren't going to get there that way. I face the problem of driving up to 5 of "my" recorders, plus feeding signal to "friends" recorders. In live concert. Shorts happen!!! After someone ruined a recording with a shorted wire, I got serious. My temporary solution is an amplifier that can drive 150 ohms, and has an output impedance of 22 ohms. Its output is well-protected up to the distribution jacks, which all have a 470 ohm resistor in series. Up to three outputs can be shorted before the amp strains. With three shorts (157 ohms) the output to the remaining recorders droops 1.14dB, tolerable. "My" recorders are fed unbalanced; "strange" recorders and especially the ones outside the booth are fed through repeat transformers to break ground.
There is still one way this can (and did!!!) go wrong. If some fool (no names) connects an OUTput to the recording bus, his signal leaks-in at 22/470= -27dB back-talk.
I would rather have a small power amplifier with less than 0.5 ohm output impedance, to put leakage down below -60dB. And a wiser man suggested "assume up to 1/3rd of outputs might be shorted at once", I have 16, so it should be able to drive 5 or 6 shorts and 470/6= 75 ohms without ANY objectionable rise of distortion.
Your case is simpler. You can only have one shorted output. (If both outputs of a 2-out box are shorted, the whole gig is off.) And you can probably ensure, or notice in set-up, if something is leaking in the "output" and causing back-talk. You have two good 600:600 transformers at good price. So get an amp that WILL drive 600 ohms. If the JMP-1 won't, add a 5534, Jensen 990, or other buffer. Hang two 470 ohm resistors on this output. (470 plus transformer loss comes to about 530 ohms, close enough to 600 ohms that a "600 ohm" amp will drive it OK.) Each resistor drives its own 600:600 transformer, and then off to whatever.
Now if one output is loaded in 10K and the other in 600 ohms, you have (10,000+530)||(600+530)= 1020 ohms, an easy load for any modern "600 ohm" output. Note that the 600 ohm load is getting about 6dB drop of voltage, but that is how matched impedances work and any box with an actual 600 ohm input should be able to deal with it.
If both outputs are loaded with 600 ohms, you have (600+530)||(600+530)= 565 ohms, OK.
If one output is shorted and the other is 600, (530)||(600+530)= 273 ohms, awful low. True 600 ohm inputs are rare, but if you expect them you should use a buffer rated for a low 300 ohm load.
If the amplifier has a non-"zero" output impedance, then level to one output changes when load on the other output changes. If you set levels before the show, and don't change connections or short things while recording, you trim this out. If you plan to step on cables while recording, and can stand a 2dB level shift (pretty negligible in speech/music), then the amplifier output impedance must be less than 132 ohms. Modern "600 ohm" outputs often have series resistors of 22 to 150 and even 300 or 600 ohms, so you want to check this point. If capacitor-coupled output, the resistor plus output cap must be under 132 ohms total impedance at the lowest frequency you care about, which implies that 100uFd may not be enough to keep bass level constant to one output when shorting/unshorting the other output, even though 47uFd is normally plenty on "600 ohm" output coupling caps.
An old old term from telegraph, adopted into telephone lingo. Mostly a 1:1 line transformer, often with center-tap.
PPR-
Everyone of your posts is school. Thank you thank you thank you.
I have decided to go the easy way and I bought a Daking pre/eq. I plan on having a direct out and an isolated out through one of my JTs according to the JT website 600:600 isolation schematic.
http://www.jensen-transformers.com/as/as010.pdf
It seems this would be more bullet-proof/ idiot-proof. My world as far as patching and gain (at least on the vocal) is concerned is set and forget. Is this worth the trouble or should I just Y-cable the vocal at the monitor desk? "Everyone does it!"
Much love-
-Mark
Yes, because it "usually works".
If it has to ALWAYS work, or fail gracefully (i.e., your signal is never degraded no matter what butt-munch thing is on the other output), you really want a Distribution Amp to completely isolate each output from the other's sins.
The JMP-1 will drive 600 ohm loads to full output swing (+24 dBm in this case using +/- 24 VDC rails) without problems. It will maintain Class A operation to about +8 dBm with a 600 ohm load. I haven't tested it with loads lower than 600 ohms. The same is true for the JFET-992 and JFET-993 discrete opamps.
If you are going to use an output transformer(s), than I would recommend replacing the 49.9 ohm output resistor (that I recommend using with our opamps) with the resistor||inductor scheme such as that recommended by Jensen... you'll want the lower source impedance to drive the transformer. I've not tested or used any of our JFET opamps with output transformers (did I mention that I RARELY use transformers in an audio signal path?) so I can't say where the limitations are.
But as is almost always the case, I agree with PRR... this time, about splitting outputs to multiple destinations and how to achive protection and isolation.
I know this is a very old thread but there's a chance to see a jmp-1 module schematic?
Or it's now copyrighted/used in commercial applications?
Thanks, best regards
Alex
user 37518 said:
I looked in the wayback machine, there doesn't seem to be a schematic published, the modules were available for sale but the page no longer exists and the JMP-1 is no longer listed in the Forssell webpage. https://web.archive.org/web/20040612074041/http://www.forsselltech.com/JMP-1.htm
Perhaps write Forssell and ask for information?
Thanks.
I looked for some information and details about it
I tried with Google with no success.
Thanks for the link.
