Free stuff; knobs, switches, caps, etc...
Rocinante
Minnehopeless
*Updated with what's left which is still quite a bit*
I feel like giving away some stuff that I haven't found a use for.  Some of it you might consider junk, other stuff I'll let you be the judge of.  There is no catch.  Instead of asking for money for shipping you can just anonymously donate to the forum.  Or not; its really up to you.  Nearly everything you see I have duplicates of and in some cases even more.
10x Bc550 and 560
25 x mpsa18
10 x tl074 (pulled from board)
10 x tl072 (pulled from board)
2 x rca 2n3255
8 x 2n2907
Behringer px1000
Various knobs -MXR style are gone now-
15mm diameter Rean/Neutrik collet knobs in .125, 6mm, and .25 shaft sizes.  There are roughly four of each shaft size. -gone-
SPST and DPDT pcb switches.
Knobs from a Yamaha compressor I believe. - gone-
Colored knobs
The any or all box of stuff.  Nearly everything in this box I have duplicates or more of
High watt resistors in various values;
if you're in need of a few values hit me up and I'll see if I have them to send you.
Caps:
Wimas and Eros
1uf 63v x 6
.1uf 63v x 6
2.2uf 400v x 2
1uf 400v x 2
.1 uf 630v x 2
.2uf 63v x 4
.12uf 63v x 8
.02uf 63v x 6
.047uf 63v
.47 100v
.68 63v
.068 100v
-Gone-
Potentiometer values:
100k log x 8 gone
10k log x 4 gone
dual gang 10k log x 4
50k lin x 8
dual gang 50k lin x 4
50k log x 6
5k log x 2
pre wired 25k log for guitar pick ups x 4
alpha rotary
3 pole 4 t x 4
2 pole 6 throw x 4
Will add more soon with more pics.
Oh and btw; thank you.
