G-Sun said:Do you mainly use 1-pole or 2-pole for your front panel power switches?
How do you wire it from there to power XF?
The power-light. Is that usually wired from the psu board?
G-Sun said:Thanks!
Why use DPDT?
http://en.wikipedia.org/wiki/Switch#Contact_terminology
And by how do I know what type of switch is quality enough?
(I've understood that I should avoid cheap switches, but what are the criteria for a good switch?)
