MrShhh
2 pole 24 way heavy duty rotary switches x 5
High quality, robust switch. Very nice to work with.
Slightly bigger than the blue "Uraltones" but do not suffer from the inevitable crunchiness after a years light use.
Nice, solid action.
Fixed 24 positions but easy to take apart and put in your own end stops.
Overall length: 56mm
Main body length: 30mm
Overall diameter: 40mm
Shaft length: 10mm
Shaft diameter: 6mm
Thread length: 8mm
Thread diameter: 10mm
Contact thickness: 0.5mm
Contact current: 3A
Rotation angle: 345 degrees
Step angle: 15 degrees
5 available.
£10 each plus £3.65 postage (1st class recorded).
or
£40 the lot plus £3.65 postage.
Nice, solid action.
Shaft length: 10mm
Shaft diameter: 6mm
Thread length: 8mm
Contact current: 3A
5 available.
or
