FS: Pultec PCBs & inductors, Grayhill rotaries, VU-meter and various others
ChrioN
Gothenburg, Earth
Selling off some old stuff never used, just collecting dust.
JLM Audio "VU buffer" built and tested. Only two left! https://www.jlmaudio.com/shop/vu-buffer-pcb.html
The meter series resistor and rectifying diode has been socketed for easy jumping when using a true vu meter or when needing a different series resistor. With every VU buffer I send 2 resistors, 2 germanium diodes, and 2 jumpers (resistor legs).
I got one of these with sockets, and one with resistors and germaniums already soldered.
Like this sans the peak hold led: https://www.jlmaudio.com/shop/vu-buffer-peak-led-kit.html
€15 each.
Photo: https://www.dropbox.com/s/cbk0tc90gkwazxm/DSC_0763.jpg
4p3t rotary switches "Made in italy". Goldplated. Banzai used to sell these.
I got 6 of these.
€1.5 each
Photo: https://www.dropbox.com/s/0cdi0opxxqsqs1t/DSC_0765.jpg
Don't know much about this meter, more than the dual needles which is pretty cool. I'm thinking one for dB compression and one for output. Or one for input and one for output. The scale obviously needs to get changed. Measures 70mm on both sides, 12mm thick, magnets and solder lugs excluded.
€5
Photo: https://www.dropbox.com/s/itannurewd6pvc3/DSC_0767.jpg
JJ ECC99 tube, used for maximum one hour.
http://www.banzaimusic.com/ECC99-JJ.html
€8
Photo: https://www.dropbox.com/s/zhywo839sh9dlyr/DSC_0769.jpg
Grayhill 2x2p6t (practically 4p6t) 1/8" shaft rotary switch. BBM. With nut and bushing. I use resistor leg and tape for stopper.
Got eight of these. https://www.digikey.com/products/en?keywords=71adf30-02-2-ajn
€7 each.
Photo: https://www.dropbox.com/s/c7pdicjjx8qodaj/DSC_0770.jpg
RCL 2p5t rotary switches. Very small. 13mm diameter body, 1/8" shaft. 36 degree rotation steps. Legs seems to be goldplated. As above, use resistorleg and tape for stopper.
Got 8 of these.
€5 each
Photo: https://www.dropbox.com/s/ut7oblhx2bkune5/DSC_0775.jpg
Inductors with free PCB.
RM8 size. One set of inductors for Franks Mid Pultec and two for Franks Enhanced Pultec.
I got a couple of PCBs of each of these, but they are corroded. Some more, some less.
Free PCBs when buying inductors!
Mid set: €52 - only one set left
EQP-1A: €18 - ALL gone
Photos:
https://www.dropbox.com/s/wcu3qi4brxfoxl9/DSC_0780.jpg
https://www.dropbox.com/s/m4vgnavye77nev2/DSC_0779.jpg
Let me know if you need any other inductors and we can work out some sort of a deal.
Shipping varries. Hit me an email if interested in anything.
How many of the Grayhill rotary switches do you have left?  The AJN ones 8)
