a couple of years ago i bought a lot of old transformers thinking about using them for some diy projects. i still have the hope to finish some of them but others i will definitely not even start.
the transformers are mostly from old german gear and manufactured by Rohde&Schwarz, Siemens Halske and Telefunken
I didn't have the time to measure transformer ratios but i added the resistance values
Shipping in Germany will be between 5 and 10 Euros, international shipping is possible
Payment via paypal or bank transfer. Buyer pays paypal fees.
a pair of Lundahl LL1577 - 45€ each
an almost completed pcb with dual analag optical compressor. missing 1 vactrol, some components in the psu part pots and power xfrmer. New tubes included. 150€
Power transformer from 1963 - only 110V - if not i would keep it - 40€
Telefunken power transformer NOS with input voltage selector - Nice for a preamp project - sec: 275V - 2x6,3V and 20V - 35€
Input transformer - shielded - 25€
the 2 left ones are sold
Rohde&Schwarz - input or interstage transformers in thick mu metal shielding boxes - 15€ each
Siemens Halske - Multitap inductors - values between 2 and 100mH - probably great for a passive eq project. will be hard to copy it - 30€
2 Rohde&Schwarz inductors - without the ferrite core aprox 2,7 H with the core completely inserted way above 20H - 12€ each
Rohde&Schwarz choke - 9H - 18€
Telefunken 1:1 line transformer - i have used them in several projects and they sound great. i found two of them but have probably more of them in another box i have to check.
25€ each. 3 available
Siemens choke 2,25H - 12€
Big Siemens power transformer with a lot of windings. i'm not sure what voltages but it was for at least 8-10 tubes - 45€
Hammond 159M - 15H @ 100mA - 22€
A bunch of caps - all tested within their specs - 5€
Just beautiful lytics from the 60ies - they still test within specs but i can't check for leaks. 5€
A very weird piece of gear - it spins and can show different patterns on the screen. just something for the museum or if you want you can build a nice c3m headphone out of it. - 90€
I will post some more stuff later. I have an almost completely stuffed analag dual opto board in a box i have to find yet, also some tubes, 2c22 for example, Jensen caps and more transformers and chokes.
Please contact me if you need more informations about the transformers. I can measure ratios if needed.
edit: more xfmers
3 x 30VA - 15V toroids - 12V each
Rohde&Schwarz - 4 available - 20€ each
Rohde&Schwarz - 35€
Siemens - 22€
Choke - 15€
Siemens Halske - 18€
Rohde&Schwarz - 22€ 2 available
nice toroid for tube projects - 40€
maybe for a lab heater psu - 25€
toroid - 35€
edit: more xfmers
Rohde&Schwarz - 35€
Siemens - 22€
Choke - 15€
toroid - 35€
