G-Pultec BOM?
sorry gents, forgot all about this.  i'll get one up w/ lead spacing in the next few hours.  if there have been component edits since the board printing they won't be reflected, as i'm working straight from that.  honestly though the component count is pretty paltry, if you've already got the board it's a quick read.
BOM:
http://www.digikey.com Part Number
2 TK4425-ND INDUCTOR FIXED 100MH TYPE 10RB
1 TK4421-ND INDUCTOR FIXED 47MH TYPE 10RB
1 TK4416-ND INDUCTOR FIXED 22MH TYPE 10RB
4 EG1953-ND SWITCH ROTARY DP-6 POS PC MNT
10 P470CACT-ND RES METAL FILM 470 OHM 1/4W 1%
10 P470KCACT-ND RES METAL FILM 470K OHM 1/4W 1%
5 BC3.3KW-2CT-ND RES 3.3K OHM METAL FILM 2W 5%
5 BC1.8KW-1CT-ND RES 1.8K OHM METAL FILM 1W 5%
5 1.00MXBK-ND RES 1.00M OHM 1/4W 1% METAL FILM
5 10.0KXBK-ND RES 10.0K OHM 1/4W 1% METAL FILM
5 1.00KXBK-ND RES 1.00K OHM 1/4W 1% METAL FILM
10 P75.0CACT-ND RES METAL FILM 75.0 OHM 1/4W 1%
1 P10248-ND CAP 470UF 16V ELECT FC RADIAL
2 P11784-ND CAP 220UF 350V ELECT TS-HC
1 P11212-ND CAP 10UF 25V ELECT FC RADIAL
1 P10312-ND CAP 1UF 50V ELECT FC RADIAL
1 P10313-ND CAP 2.2UF 50V ELECT FC RADIAL
3 E2224-ND .22UFD/250VDC METAL POLY CAP
1 E2334-ND .33UFD/250VDC METAL POLY CAP
1 E2474-ND .47UFD/250VDC METAL POLY CAP
1 E2684-ND .68UFD/250VDC METAL POLY CAP
2 E2104-ND .10UFD/250VDC METAL POLY CAP
1 E2223-ND .022UFD/250VDC METAL POLY CAP
1 E2153-ND .015UFD/250VDC METAL POLY CAP
2 E2103-ND .01UFD/250VDC METAL POLY CAP
1 E2123-ND .012UFD/250VDC METAL POLY CAP
3 E2333-ND .033UFD/250VDC METAL POLY CAP
1 E2683-ND .068UFD/250VDC METAL POLY CAP
1 E2154-ND .15UFD/250VDC METAL POLY CAPHL
2 E4473-ND .047UF/400VDC METAL POLY CAP
2 LM317AT-ND IC REG POSITIVE ADJ TO-220
http://www.mouser.com
2 31VA301 POT 1K OHM 1/4W CARB LNR TPR
1 31VA401 POT 10K OHM 1/4W CARB LNR TPR
1 31VJ501 POT 100K OHM 1/4W CARB AUD W/SW
1 31VA303 POT 2.5K OHM 1/4W CARB LNR TPR
10 ME450-1017 Black Knobs 1/4" hole 1" total dia.
1 1429-2475 Xicon Radial Metallized Poly Cap 4.7u 250
1 532-507102B00 Heat Sink
1 504-GDB-4A 4A 250V time delay Fuse
2 504-1A3399-10 Fuse Clip
Other Sources:
1 ECC88/6DJ8  GE Tube $20,00 $20,00
1 9 pin tube Socket $2 $2
2      LL5402         Lundahl Transformers
1                              2HE Chassi
1                              2HE Front panel Service. Awesome looking g-pultec 4mm panel in pultec style, powder coated, that i designed years ago.
http://www.don-audio.com/2HE-Frontpanel-EQP-1A-Look-engraved
1              Power Trafo http://www.don-audio.com/g-pultec-power-trafo-sec-220v-9v-5V
1 2.2uF Cap 0,4 $0,40
1 1uF Cap 0,4 $0,40
1 ICO-1PBS18 0.018 uF Cap  (18n) 0,4 $0,40
1 ICO-6PSD68 0.0068 uF Cap (6n8) 0,4 $0,40
1 ICO-6PSD33 0.0033 uF Cap (3n3) 0,4 $0,40
1 SWI-EAC309 Standard AC Plug Socket 0,3 $0,30
1 sWI-C3M XLR Male socket 5 $5,00
1 SWI-C3F XLR Female socket 5 $5,00
2 NTE-5304 Rectifiers 400V 1.5A 1,75 $1,75
1 PHI-30-15203 Rotary Switch 2,8 $2,80
1 ELN-RE2-25V472M 4700uF 25V Electro Cap 1,75 $1,75
2 SWI-14B 1/4" TRS sockets 1,2 $2,40
For the high section it is very tasty to use Styroflex caps.
Can´t be wrong searching for those values.
1.0nF x 3
1.5nF x 2
3.3nF x 2
4.7nF x 3
10nF x 4
15nF x 2
22nF x 5
33nF x 1
This is a very great sounding EQ circuit. One of my favorite an most used eqs in my project studio!
A big Thanks to Jacob from Gyraf Audio who made it possible and Gustav who is still producing the pcbs.
Thanks so much man!
What would be a good substitute for these ???
"2  TK4425-ND  INDUCTOR FIXED 100MH TYPE 10RB
1  TK4416-ND  INDUCTOR FIXED 22MH TYPE 10RB"
Digikey says they are obsolete and their recomended substitute is a minimum 1000 qty.
Niely- pretty certain RS still carry those inductors... Or see if anyone has the IOAudio custom inductor they're prepared to let go of...
Something i found..
Electrolytic capacitor
1 pcs 10uF
1 pcs 4700uF
2 pcs 220uF
1 pcs 470uF
Polyester capacitors
1 pcs 4,7uF
3 pcs 220nF
2 pcs 100nF
2 pcs 47nF
3 pcs 33nF
1 pcs 22nF
2 pcs 15nF
2 pcs 10nF
3 pcs 330nF
1 pcs 470nF
1 pcs 680nF
1 pcs 1uF
1 pcs 2,2uF
3 pcs 3,3nF
1 pcs 6,8nF
1 pcs 2,2nF
1 pcs 150nF
1 pcs 68nF
Tubes and sockets
1 pcs E88CC tube
1 pcs Tube socket, Noval
Pots and switches
1 pcs 2K lin pot
1 pcs 10k Log pot
1 pcs 1k lin pot
1 pcs 10k lin pot
1 pcs 100k log pot
3 pcs 2x6 rotary switches
Transformers
2 pcs Lundahl 5402 (audio)
12/250V secondaries (power)
Rectifiers
2 pcs diode bridge rectifier
1 pcs LM317
Resistors
2 pcs 470K 3W
1 pcs 10K 3 W
1 pcs 1M
2 pcs 470R
3 pcs 10K
1 pcs 470K
1 pcs 1K8
1 pcs 2K2
2 pcs 1K
1 pcs 75R
Mounting
1 pcs XLR male
1 pcs XLR female
IEC connector
Fuse holder, Fuse
Case
Wire
nuts, bolts
Knobs
