marktokach
It seems noise level is very low and fig 8 seems to work well as does omni mode. Cardioid mode however is very low output and low bass response. I cleaned everything with alcohol and got rid of some noise I had when I first finished it. The only thing I can think of is that I did a flux wash before I was finished and did not know it could harm styroflex caps which were installed. I saw a post from someone, Salossi I think, that had low output from omni mode and replaced the caps and solved his problem. Sounds like this could have something to do with it so I'm going to try replacing them. One question is what do these styroflex caps have to do with the pattern switching? Any other ideas I may be missing? TIA
P.S. It has a Dale M7 capsule and an Ioaudio body
