G7 - Parts...
BackHand
Sweden
Hi guys!
I've tryed not to write on the forum and searched all I can..but I'm a newbie.....so I still have some questions regarding parts for the G7 microphone... Rolling Eyes
Maybe you pro's out there could help me :razz: !?
I've got three Iaudio bodys and Dale's M7 capsules..so that part has been taken care of...and the Lundahl I'll manage (I live in sweden so maybe it's a little bit easier for me !
Now I'm going to order the rest of everything..allt the stuff for the PCB's and the Tubes..and I've tryed to follow your "Components List" but I've stumbeled over some questions...
My goal is to buy only the best components to make thess microphones as good as they can get...the only thing that I'm trying not to spend a stupid amount of money on is the tubes since I've read that they don't really effect the sound so much in your G7 design?
I'm doing an order for all of this at RS Online (http://www.rsonline.com) since I've read that they have everything an so forth..to make it easy..
If you could please check this list for components and maybe come with suggestions of changes (maybe with part numbers from their site?) I would be more than thankfull Heck Yeah!
I don't know anything about watts for the parts or what kind to choose and so forth..only guessed and tryed to folow your list..
This is what I got to this far:
"G7 Mic
247-7856 - Resistor,highRic,thick film,metal glaze,0.25W,1G
247-7783 - Resistor,highRic,thick film,metal glaze,0.25W,33M
214-3115 - Resistor,metal oxide film,power,3W,470k
149-925 - Resistor,metal film,0.5W,1%,100k
149-818 - Resistor,metal film,0.5W,1%,10k
148-556 - Resistor,metal film,0.25W,1%,1k6
149-650 - Resistor,metal film,0.5W,1%,220R
215-5714 - Capacitor,electrolytic,aluminium,audio grade,solder tag,35Vdc,100uF
166-6099 - Capacitor,film,metallised polyester,radial,1822,MKT,100°C,±10%,160V,2.2uF
108-2980 - Capacitor,film,metallised polyester,radial,miniature,MKS 4,100°C,±10%,63V,1uF
PSU
631-317 - IC, Voltage Regulator, Positive Adj, LM317T
414-8831 - Capacitor,electrolytic,snap in,2 pin,TSUP,200V,470uF
315-0631 - Capacitor,electrolytic,aluminium,low impedance,radial,wire ended,25V,2200uF
547-8486 - Capacitor,aluminium,electrolytic,radial,subminiature,SRE,85°C,±20%,35V,10uF
148-562 - Resistor,metal film,0.25W,1%,1k8
374-6917 - Trimmer,Cermet,single turn,miniature,7mm,4.7kOhm
148-427 - Resistor,metal film,0.25W,1%,470R
214-1276 - Resistor,metal oxide film,power,1W,10k"
185-4347 - Capacitor,metallised polyester,axial,wire ended,400Vdc,0.1uF
113-409 - Capacitor,tubular foil polystyrene,axial lead,160Vdc,10000pF
113-320 - Capacitor,tubular foil polystyrene,axial lead,160Vdc,1000pF
347-2537 - Transformer,encapsulated,PCB mount,5VA,230V pri,2x0-9V sec
805-546 - Transformer,PCB mount,3VA pri,230Vac,50/60Hz,sec,2x0-15V
659-832 - Diode,Bridge Rectifier,W049
Any suggestions for what EF86 tube to use that is not to expensive and still good enough for the rest of the components?
Thanks a lot !
/ Calle
sorry i have no suggestions for you. i'm located in the us and i'm also working on a g7. sourcing the parts seems to be very time consuming. i'm using a pcb(gustav) and have all the parts ready to go. when the mic is assembled and working i am planning on posting a parts list with sources and catalog numbers. this will only be good for those in north america however. when you get your mic up and running could you pm your list to me or post it in the same thread. this way there will be one location(thread) where someone can easily source the parts for this project in both north america and europe.
I second that...
I'm also in the process of building a G7. I'd estimate I'm 70% finished. I ordered my capsules and tubes yesterday, and I have to box up my PSU (which I tested). I don't want to post anything prematurely and it be wrong. I will have a complete parts list as well once I'm complete.
