Yesterday i've built PSU for Gyraf G7 mike.
My polarization voltage (RMS) is circa 185V?!?
I measured it without load. With load it should be little bit lower i think, but is it possible to get lower about 25V?
Am using custom toroid transformer with 135VAC and 9VAC on secondary windings and selenium rectifiers on both.
Two 470uF capacitors, 10k resistor and two 100k resistors for the pattern switch.
Any ideas what could increase polarization voltage that high? Is it possible that selenium rectifiers could increase voltage more than silicon rectifiers?
