Gachet
Hi everyone,
I've build a g7 using tim campbell capsule, and it's not working as it should.
It probably works fine in bi directionnal mode but when i switch to omni I can hear only hi frequencies, as if I had a phase related problem.
In cardio mode the back capsule only catches low frequencies.
This is how I've wired the capsule:
The two terminals on the side of the capsule are wired to center.
The front and back terminals are wired to front and back
I've read the meta about that kind of problem and changed the two styroflex cap close to the capsule, no change.
I've checked voltages it seems fine.
Is that possible wiring should be different?
Is there anybody who successfully achieve a g7 using tim campbell's capsule?
