G
Guest
Guest
If you have 68V at the anode your tube is drawing about 0.62mA. This is not too bad. Check the voltage at the cathode (K) pin 3 to verify this.
With power off, check resistance on the LL1538. Between pins 5 and 6 should be about 880ohms. Pins 1 and 2 should read 44 as should pins 3 and 4. There should be open between all other pin combinations and pin 6 is grounded. Not to be too confusing, but you could connect the pins 2 and 3, and pins 1 and 4 like the data sheet and have less chance to pick up noise. Just connect the traces where they are cut on the board.
If this measures OK lets see what we can do to find sound. Are you sure the speaker you are plugging into is OK? Try to measure AC at pins out + and out - while you make noise into the mike like clapping or something.
Try the above and let us know what you get.
