jdbakker said:
[...] a 6dB output pad also gives better low-gain noise performance than either increasing the attenuator in front of the last amp or reducing the last amp's gain.
Doing some noise calculations (more on that later) it appears the difference is bigger than I first assumed.
Consider the proposed plan:
at its lowest gain, 20dB. For now let's ignore the noise of the gain blocks and pencil in 600R for the attenuators. For an input (mic) resistance of 150R, an ideal noiseless amplifier would hiss like 150R*10(20/10)=15k.
As drawn, the output of stage 1 hisses like 150R*10(26/10)=60k.
The first attenuator is set for 20dB, so after this attenuator the input contributes 60k/10(20/10) or 600R. Add to this the resistance of the attenuator (also 600R) and you get 1200R at the input of gain block 2.
Gain block 2 amplifies this by 20dB, so at its output we see 1200R*10(20/10)=120k worth of hiss.
Second attenuator is also set for 20dB and has a resistance of 600R, so at its output we see 1800R.
Third gain block amplifies this to 180k.
The third attenuator cuts this by 6dB for a final noise resistance of 45k, or a
4.8dB noise figure.
Now if the output attenuator is removed and its attenuation is moved to the second attenuator (now 26dB), the input of the second attenuator still sees 120k, reduces this by 26dB to 300R, add its own resistance to get 900R at the input of gain block 3.
Gain block 3 amplifies this by 20dB, to arrive at an output-referred noise resistance of 90k, or a
7.8dB noise figure.
On the other hand, if you keep the output attenuator and switch out the second attenuator and gain block for lower gain settings, the noise resistance is 30k, for a
3dB noise figure.
PRR said:
I assume you are allergic to transformers.
Not at all, and what you suggest is intriguing, and definitely better than an input pad. I'll ponder this a bit more, and will go looking for appropriate iron.
As a matter of fact I would prefer a 2400:600 output transformer (plus some output load isolators) over a resistive 6dB output pad, but even a cheap specimen will cost a significant fraction of the BOM for the entire pre, especially if you factor in shipping.
JDB.
