M mkiijam Well-known member Joined Aug 25, 2017 Messages 179 Jan 24, 2024 #1 Rebuilding this and noticed a previous tech replaced the 16 uFd 450v cap but installed it as to "bypass" R50 the 4k7. See attached picture. Is this okay? I need to replace the cap as it is leaking. So I can put it back the right way if it matters.
W Walter66 Well-known member Joined Jul 13, 2020 Messages 197 Jan 25, 2024 #2 Well, R50 drops voltage down by 40V. Otherwise the circuit would see 275V instead of 235V, which is original. I wouldn't bypass this filter resistor.
M mkiijam Well-known member Joined Aug 25, 2017 Messages 179 Jan 26, 2024 #3 The resistor is still there, it's just where the cap is attached.
ruffrecords Well-known member Joined Nov 10, 2006 Messages 16,311 Location Norfolk - UK Jan 27, 2024 #4 It is not clear to me what has changed. Can you post the whole schematic? Cheers Ian
M mkiijam Well-known member Joined Aug 25, 2017 Messages 179 Jan 27, 2024 #5 here Attachments SA_39B.jpg 5.8 MB · Views: 1
