[quote author="Gert"]Don't they use the LM3886 as poweramp?
Gert[/quote]
No, not at all.
From memory, they use discrete component amplifiers. There is a central heatsink with the output drivers bolted to it. I've had problems with the molex connectors and I've had the fuses blow, but that's been most of the problem.
Check the molexes, then look around inside. It's not all that difficult, luckily.
-Also -Remco, I've got those switch caps for you... just been a bit busy recently, I'll go through everything this week, I promise!
Keith
