Emperor-TK
So far I've built a G7, a G9 and am currently starting on a GSSL and a second G9. I had always wondered about the relays used in the G9 for input switching. I have also noticed that relays were suggested in a GSSL thread for make-up gain bypass (with a DPDT lighted pushbutton bypass switch). I understand that relays (both SSR and solenoid) are often used for switching high voltage/high current sources that would fry a normal mechanical switch or could be potentially dangerous if shorted.
What is the design consideration in having them in audio devices?
Would there be any negative results from using a 2x6 Lorlin to do both bypass and makeup gain bypass on the SSL?
-Chris
-Chris
