Germanium transistors in early Sennheiser MKH microphones
Gerard
Ireland
I have some old Sennheiser MKH 110 mics which are noisy, and one that is dead. The latter I loaned to someone who plugged it into a P48 supply and blew the transistors; the MKH 110 uses an 8 V power supply.
According to the circuit diagrams I can find, the MKH 110-1 used an AT 125 in the oscillator and an AC 125 transistor in the output stage. I can find AC 125 transistors at a price, indeed I still had a couple of AC 126 transistors from my first interest in electronics around 1970, when I was only 12 or 13 years old.
What is the difference between the AC 125 and AC 126? Looking in my ancient copy of Towers, I can't see any significant difference. Would AC 126 be a suitable replacement for AC 125 in an RF-biassed microphone?
I can find nothing online or in Towers about the AT 125. Does anyone know what it is and what might be a suitable alternative?
The same except AC126 has a bit higher HFE
Yes, it would be the same or marginally better
I think AT125 doesn't exist, never seen any germanium transistor that starts with "AT"
I think the transistor is an AF125, as the schematic has lower resolution the F looks like a T, but if you look closely you can see the "F" there
So it should be an AF125, which makes much more sense.
Thank you very much. Just spotted your reply.
I have some AC126 transistors, so OK there. Someone else has also suggested AF125 for the oscillator just based on the circuit topography and oscillator frequency; I wonder if I can still find AF125 transistors.
Well, I opened up a couple of MKH 110s and did not find a single AC 125 or AT/AF 125. Instead I found what might be a BC 5608 or BC 6608 (partially covered in red paint, so probably 'selected') and a something-something 5608 in one mic, and a BC 107 and a BC 214K in the other one. Does that make any sense to anyone? These are both MKH 110 mics, not MKH 110/1 or MKH 110/2.
    1.4 MB
    1.5 MB
    1.1 MB
    1.4 MB
Yes, I think you are correct; now I look again, the last character does look like a B. I wonder what the red paint signifies? Maybe selected for 8 MHz? Could a BC560B operate at that frequency? fT seems to be typically 250 MHz, so 8-10 MHz should not be a problem for it.
Bear in mind , these mics are old ,they may have been modified along the way with whatever transistors came to hand , might be part of the reason they sound poorly .
Chances are these mics went through several revisions as silicon technology advanced down through the years , Its hard to find people with the expertise that are even willing to service these MKH's
As you might have seen Ger , I've scored a pair of MKH mic bodies plus capsules minus interference tubes , they look like 415's 416's , I was thinking of a xlr barrel jack with a mini 12v cell inside rather than the bother of trying to use phantom or dedicated mains psu .
The differences between germanium transistors and silicon transistors are very significant.
Best regards!
