Gibson Skylark Guitar Amp
6AQ5's in push pull, nice sounding 6V6 type in a smaller envelope,
schematic is different, as always, from those you find online as things change.
nice sounding Tremolo!
    232.2 KB
unique square wave from the output transformer,
top is 1 KC, then 10 KC and 100 KC on bottom,
and also note weird response from OPT print above, starts rising at 5K ! never seen that,
then keeps rising to 100 K with a few surprise dips and peaks after that.
    173.4 KB
it is very rare but it happens, factory wiring error,
thought we had a wiring error, but pin 1 and pin 7 are both G1.
    134 KB
very quiet amp, 6EU7 preamp tubes, 6X4 rectifier, had a cap job already with the old carcass intact>
    167.5 KB
A good pal of mine got a JCM800 combo as a gift from a music store that was closing down .
The amp had sat there for 30 years ,returned by the original customer as the boost channel was intermittant, worked the very odd time .
Was a mystery to all untill I got to have a look at it , turned out pins 4 and 5 of a preamp 12ax7 werent soldered together , only one heater section of the dual triode fired up.  A quick touch of the iron and he was back in business .
Gibson amps are rare as hens teeth here this side of the pond , I dont think I ever laid eyes on one in the flesh ,
They did seem to know a thing or two about crunch and tone though, 6AQ5 or 6BQ5 in duets or quads throws out piles of volume cranked , worlds apart from Fenders offerings of the late 60's many of which were loud n clean and dont distort very gracefully .
Thanks again for the interesting post .
Do you think they did not care about the transformer response because guitar does not go that high in frequency?
