Hi!
I'm considering going to use 4 layers pcb for my next audio layouts. I know there is a thread explaining the pros and cons and how to layout things... Ok so far.
In my case I used to use two layers and used wire jumpers for all connections that crossed other traces on the top layer, in order not to trace anything on the bottom layer, and maintain the bottom gnd plane uncut. It worked well, and also used stitching for copper areas. All this worked well.
Now, the easiest way for me to go to 4 layers is to replace all top layer jumpers, with traces on the bottom layer, maintain SIG/PWR on top layer as I always did on my 2 layers boards, and, as the second and third layers are just copper with no traces, and are stitched with all the 4 layers, I think it could work, because the bottom layer traces have their return path in the third layer, and the top layer signal/power will have their return path in the second layer.
I know it is more complex than this, but I think all this makes sense, and the only way to prove it works is to order some boards...
Just wanted to share my thoughts because I feel I'm entering the unknown zone....
Jay x
Jay x
