Great River MP-2 preamp
Winnipeg Mb Canada
Pdf's for the Great River Mic pre , courtesy of Dan Kennedy
see the thread in preamp section for build notes & trouble shooting
http://www.groupdiy.com/index.php?topic=20333.0
  • supply schem.pdf
Bom
http://www.matt-allison.com/diy/greatrivermp2/MP-2%20bom.txt
Matt's a pretty good guy, but you should double check if you have an idea about what you're doing.
Bill of Material for C:\GRE\DWG\CURREN~1\AAUDIO.Sch
Used Part Type      Designator          Footprint  Description Part Field 1
4    .01uF/250V    C23 C31 C35 C39      RAD0.16                P10955-ND
5    .47uF/63V      C1 C2 C24 C27 C3    WIMA-47                3017PH-ND
4    100R          R14 R17 R21 R29      AXIAL0.4              100XBK-ND
1    100uF/35V      C42                  RB.14/.32              P10294-ND
1    10R0          R34                  AXIAL0.4              10.0XBK-ND
7    10uF/50V      C22 C30 C32 C33 C34  RB0.079/.2            P10316-ND
                    C36 C37
3    10uF/100v      C38 C40 C41          RB.1/.25              P10769-ND
1    18uH          L1                  AXIAL0.6              Factory
2    196R          R10 R11              AXIAL0.4              196XBK-ND
1    1K00          R24                  AXIAL0.4              1.00KXBK-ND
2    1K10          R3 R4                AXIAL0.4              1.10KXBK-ND
4    1N4004        D10 D11 D12 D13      DIODE0.4L              1N4004RLOSCT-ND
11  1N4148        D14 D15 D17 D18 D3  DIODE0.4              568-1360-1-ND
                    D4 D5 D6 D7 D8 D9
1    1N4750        D16                  DIODE0.4L              1N4750ADICT-ND
2    1N5251        D1 D2                DIODE0.4L              1N5251BDICT-ND
6    20R            R30 R31 R32 R33 R36  AXIAL0.5              P20W-1BK-ND
                    R47
1    220pF          C20                  RAD0.2                P3221-ND
6    221R          R15 R18 R38 R40 R42  AXIAL0.4              221XBK-ND
                    R44
2    2K74          R27 R28              AXIAL0.4              2.74KXBK-ND
2    2N4401        Q13 Q5              TO-92B                2N4401RLRAOSCT-ND
4    2N4403        Q12 Q2 Q3 Q4        TO-92B                2N4403RLRAOSCT-ND
1    2SK-389        Q1                  2SK-389                factory,
4    38R3          R19 R20 R26 R35      AXIAL0.4              38.3XBK-ND
3    3K83          R25 R39 R41          AXIAL0.4              3.83KXBK-ND
1    42K2          R6                  AXIAL0.4              42.2KXBK-ND
4    470uF/50V      C25 C26 C28 C29      RB.2/.4                P11260-ND
2    475R          R5 R9                AXIAL0.4              475XBK-ND
1    47R5          R12                  AXIAL0.4              47.5XBK-ND
3    49R9          R13 R22 R23          AXIAL0.4              49.9XBK-ND
1    562K          R8                  AXIAL0.4              562KXBK-ND
1    5R62          R45                  AXIAL0.4              5.62XBK-ND
16  680uF/10V      C10 C11 C12 C13 C14  RB.14/.32              P10222-ND
                    C15 C16 C17 C18 C19
                    C4 C5 C6 C7 C8 C9
1    68pF          C21                  RAD0.2                338-1091-ND
2    6K81          R1 R2                AXIAL0.4              6.81KXBK-ND
2    8K25          R16 R43              AXIAL0.4              8.25KXBK-ND
2    9K09          R37 R7              AXIAL0.4              9.09KXBK-ND
1    GAIN          J5                  MLSS-100-3            *
1    HI-Z JACK      J4                  MLSS-100-3            *
1    LM-317T        U1                  TO-220                LM317TNS-ND  + heatsink HS107-ND
1    LM-337T        U2                  TO-220                LM337TNS-ND  + heatsink HS107-ND
1    LM317          U3                  TO-92C                LM317LZNS-ND
1    MIC IN        J1                  MLSS-100-3            *
1    MJE-171        Q17                  TO-225A-H              MJE171OS-ND  + heatsink HS107-ND
1    MJE-181        Q16                  TO-225A-H              MJE181OS-ND  + heatsink HS107-ND
4    MPS-8099      Q10 Q11 Q14 Q9      TO-92B                MPS8099RLRAOSCT-ND
4    MPS-8599      Q15 Q6 Q7 Q8        TO-92B                MPS8599RLRAOSCT-ND
1    OUT            J7                  MLSS-100-4            *
1    POWER          J8                  MLSS-100-5            *
2    RXE-040        RF1 RF2              RAD0.2                RXE040-ND
1    SWITCHES      J6                  MLSS-100-5            *
1    TBD            R46            Typically 750<<3K32          *
2    TN2E-24V      K1 K2                TN2RELAY  TN2E        255-1024-5-ND
1    XFORM PRI      J2                  MLSS-100-3            *
1    XFORM SEC      J3                  MLSS-100-3            *
