green pre PSU ground
dustartist
Active member
I read the meta regarding grounding, and it raises a question about grounding the power supply. I have the ground wire from the IEC inlet connected to the star ground, and pin 1's (output & input separated) connected to ground. Can I just use the GND terminal on the circuit board to connect the PSU to the star ground?
