bjoneson
Working on a Scully 280B deck from around 1977. The main power supply has multiple taps on the primary for different mains voltages.
It was set up for 115V, but has taps for 105, 125, 220, 240 as well.
I've been troubleshooting another issue with the machine with an unregulated supply running a bit higher than spec.
My mains voltage sits consistently around 122-123V, so I decided to move to the 125V tap on the transformer.
Now, any time I engage the transport, I get a very noticeable 60Hz hum from the outputs.
There are certain transport functions that do not cause the hum. Such as EDIT, and with the ATL defeated on fast wind mode.
I'm perplexed that simply changing the tap (essentially dropping the supply by 10V, would have this affect.
Returning to the 115V position removes the hum.
Any thoughts on what is creating this hum?
(PSU Schematic Attached)
