groupDIY 500 series mechanical specifications
sorry for the confusion, GndB is Power Ground....
pin 13 of Edac Connector.
GndA is pin 5.
till now I haven't had any problems connecting both GndA and PwrGnd at 0v
also for xlr pin 1 using GndA, and safety Earth to chassis only, just for testing its behavior
signal is very clean and also the last module plugged close to psu presents no issues
I apologize to everyone if my questions and requests are in a post where only mechanical infos should be shared
but I think it is useful for those who want to go for a psu like this in a DIY lunchbox and so don't make any mistakes
best
No case for an apology.
I am glad that it is working fine.
In my limited experience , a kind of mechanical connection "standard" between the front panel and L bracket or something similar would help a lot with alignment issues and the odd potentiometers sticking out. It seems like an L bracket is kind of a luxury in the DIY 500 series world
Since the front panels have limited real estate , having nuts visible is not the prettiest of sights. Some knobs definitely cover those but others barely do
Seems like it would be a relatively easy undergoing for someone here !
Here you mean the backplate on which the PCB is mounted and the fixing between the backplate and the front panel (which we call faceplate).
On our modules the backplate is fixed to the faceplate through threaded inserts/standoffs that are inserted into the faceplate. You can not standardise such fixing as the locations of the standoffs will be dictated by the front panel layout.
this is a sort of template i created for my 500 front panel
just placed quick quotes to be read, i know is not the proper manner to do that, but for me is enough to get a working proto....
dotted lines are 2 pcbs, stacked with Ettinger cube 12mm x 12mm
panel dimensions according to MidnightArrakis advices
purple holes for M3 mounting
also some time ago i spoke with Frank from FrontPanel.de, he advised a width of 37.7mm if i remeber well, but it's your choice i believe, according to clearance you want to obtain between modules. the important thing is the dimension between the main mounting holes and the center of the lower pcb, to get the Edac axis
with the attached drawing my last build fits easy and perfect with no stress into an original Api box
hope this helps
    10.6 KB
