Hi Mich,
Yes, the two halves of the TL072 are switched between schematic and PCB.
Is your timing circuit working right, giving relatively slow changing DC with signal?
There is a small jumper on the front panel pcb (near the centre where the incoming wires attach) that will prevent timing from working if it is left out by error. check that this jumper/wire link is mounted correctly. This has been a known error before.
Jakob E.
Jakob E.
