Kent,
Look at the schematic.
Even though this is a feed-back design, there's no DC feedback path. This means that we are either looking at noise disturbing the sidechain, or one of the DC-blocking capacitors are leaking..
Check for DC at point "C" without signal. If there's DC here with no signal, then either you have some HF oscillation or the 22uF electrolytic in the input of the sidechain rectifier is leaking DC (the one after TL074 pin7).
Check DC at the output of the A/R timing buffer, TL074 pin8. This should follow the signal on point "C" plus some timing - metering actual GR.
The threshold pot only adds some extra gain to the sidechain VCA, so whatever messes up must be a signal present at the input of your sidechain.
Try tracing your signal through the unit - for both AC and DC.
Check your supply voltages - specially the +/-12V should be stable and noisefree..
Jakob E.
Jakob E.
