salomonander
- Joined
- Aug 28, 2011
- Messages
- 951
thanks weiss,
well i have some issues with unity gain due to adding a cavendish board. but that should not matter now as im running on ics atm.
there are two other things that seem dubious to me:
the ratio: when feeding a low to moderate level input 2:1 always does more reduction that 10:1. at some point (level) this flips and 10:1 actually show the most compression. reading through this thread is a pain. but from what i gathered this might be normal?
threshold: the way this sits atm i can get barely any compression when feeding a 0db sinus (as needed for meter calibration). i certainly can't get 10db of compression. there is a resistor on the control board (47k*) that supposedly reduces threshold sense. maybe jumper that?
cheers
cheers
