Hi all,
I just finished a gssl bus comp, and iafter some tests i have this problem :
Without the sidechain board, the signal is well compressed. But since i wired the super sidechain board, the threshold is completely insufficuent to compress the signal..the vu meter just moves a little bit, even with threshold completely counter clockwise.
Did somebody have the same problem ?
I assume the main pcb is ok, and the wiring is ok too, i check resistors and ceramic caps of super sidechain board, good values...if you have any idea please share it.
Can i change the threshold pot with a higher resistance or will i lose something in term of quality ?
