GSSL with TURBO and ONE SSC board wiring
here is the Purusha case,
nice case,
but cuts for SIFAM AL19B ( rare and expensive, not as much as PPM14 but...)
cuts for EAO switch ( rare and expensive, )
sidechain board
turbo board,
this little beast will cost me alot of money afterall!!!
pacemaker said:
Hi Stich-O?
you have understand correctly what i need,
Wire both a Turbo and SSC switchable with ONLY a SPDT switch.
the problem came with Persuha cases,
GSSl white turbo etc...
http://purusha.smokinggunrecording.com/diy/G-SSL1.jpg
As already pointed out you need a DTDP relay wired to your SPDT switch.
http://www.kpsec.freeuk.com/components/relay.htm
You'll need to provide the necessary voltage and circuitry to do the switching, but
it's not complicated.
Here's a $15 kit that should get the job done.
http://www.electronickits.com/kit/complete/elec/ck1619.htm
Mark
Sorry to revive this old thread but I am trying to connect my SSC and turbo in the manner suggested in reply 4. I see there is 2 100k resistors in place of the 100R and 56R. Is this correct?
Hi guys is anybody have a schematics of turbo board or pcb layout for it.
I built a GSSL compressor and I want to make a turbo board to see what is diferencies in sound.
Best regards
hi, i understand for the hpf filter to work in turbo mode you need 2 supersidechain boards? So when I don't use the turbo mode, the filter won't work?
