On the photo, there are API and HDD screws. API is an American company, and HDDs often also have imperial screws.
So it’s probably the other way around. Two screws to the left are imperial, the right one is M3.
Different pitches on M3 are very rare and chances to meet such screw are slim.
EDIT. Never mind. I reread your first post. If you tried M3 and it didn’t work, than it’s probably either imperial or different pitch.
The first one I think are the screws for mounting kits for drives either 3.5 or 2.5. I tried several versions of those that I received but to no avail.What sort of "hard drive" is that first screw for? 3.5" drives have #6-32 (imperial) threads; 2.5" ones have M3.
If it's the former, API one may well be #4-40 (coarse), major diameter about 2.8mm (across the tips of the thread form) and 0.635mm thread pitch, which would make the mystery screw actually a normal M3x0.5.
Later edit: here's some screws i had around - 6-32 and 4-40 (out of a MOTU made in USA audio interface), and an M3.
Lindell says they chose the M3 because it is more common and easier to find than 4-40. Maybe that’s the case in the EU?
