abbey road d enfer said:Correct.
Thank you sir
On my way
Just a quick question regarding the switches... I suppose a MBB switch with the resistor is preferably since there will be a load at all times? Or am I wrong here?
Best regards
// John
abbey road d enfer said:Not really, there's something fishy in the way the output switching works. The amps should feed the common of the switches.
That could be an important part of a better solution.johnheath said:I suppose a MBB switch with the resistor is preferably since there will be a load at all times? Or am I wrong here?
squarewave said:That could be an important part of a better solution.
The one that doesn't make your tubes flash blue.johnheath said:What is that better solution?
squarewave said:The one that doesn't make your tubes flash blue.
Trying to switch a load and not have it change at all is actually quite hard. I think that's primarily why you're not getting the answer you're looking for.johnheath said:If this is a too hard nut to crack for please just say so... I can take it, but I was in fact just asking for advice
squarewave said:Trying to switch a load and not have it change at all is actually quite hard. I think that's primarily why you're not getting the answer you're looking for.
The requirement that you have to be able to switch while the amp is on is a major problem. So just don't do that. If you turn the amp off (or to standby), then a simple AB switch would work. You could just use the circuit you posted or buy an AB switch.
squarewave said:A secondary reason I think you're not getting the answers you're looking for is because I don't think you're really thinking things through. For example, the resistors were to try to deal with switching a live amp. But if it has been decided that you'll never-ever switch the amp unless it's off or in stand-by (just like you would never pull the speaker cable out of a live amp), then you don't need load resistors at all. Right? And, as others have suggested, it's not clear that 620 ohms would prevent a failure anyway. And, even if you did use them for whatever reason, the heatsink requirement depends on the power they dissipate which is something that you can compute using ohms law. For a 50W amp tha'ts 20V / 8R = 2.5A * 20V = 50W. So if you used 620R resistors that's 20V / 620R = 0.032A * 20V = 0.65W. Under a watt. Depending on the specific resistor used, that probably doesn't need a heatsink at all. So like I said at the end of my last message, use and A/B box and just never-ever switch the load while the amp is on.
clintrubber said:FWIW, you might have already seen this one:
the Palmer TINO "TwoINOne" might not be exactly what you're looking for,
but perhaps might provide some info or inspiration?
PRR said:The "8 Ohm" do not have to be exact. 2:1 either way may lead to a Common Value. 10r is convenient. (However 8r power resistors are sold as Dummy Loads rated for more power than most tube amps.)
We could observe that ALL tube amps survive heavy beating at speaker bass resonance which is often 50 Ohms. And power in 50r is maybe 1/3rd the power at 8r. (Not 8/50 because the amp is lossy at nominal load, and light-load voltage rises more than a transistor amp.)
See attached schemo.johnheath said:Hmm... wouldn't that require four speakers? I mean each amp connected to common of the switch... That would be easier just to have speaker connected to each amp but then the choice of selecting speaker for each amp would be gone wouldn't it?
Not realistic. Such a typical relay needs about 500mW to energize.Tubetec said:maybe you could hijack 48v phantom from the desk to power the relay
No. The relay coil can be completely floating from the audio circuitry....but loose the ungrounded advantage by doing so .
You can't leave a tube amp unloaded, even without signal.moamps said:Dummy load isn't needed at all if only one amplifier works at a time (another one is muted at input).
