Hi all,
I've seen some info on this but would like to clarify if I could. I'm messing around with a filter section built to the G pultec. I've also included the 220 cap on the output and the 470k resister from that point to ground as in the original gyraf schematic that is prior to the tube make up stage. It works great going to a line level input of another device for make up. If I wanted to go to a mic Pre for make up, should I use a transformer type di in between?
