Now not really. EI trafos can generate more noiseOhhhh but should we use toroidal transformers. Is there any problem if we use 2 ordinary transformers. 230: 12 and 12: 230 as specified in the circuit
No its hard to say how noisy a trafo is in real life. Expect some noise issue. I build a pulltec with EI trafo and unshielded inductor. It has some noise. If you want really quite I think you should shield the inductor and take good care of grounding scheme...Ohhh so you're saying it's important to use toroidal transformers?
Yes the one in the filter section. In the original Pultec the filter section was shielded and encapsulated. In my latest inductor eq build. I sheild the inductors + I use external PSU. But u never Know how much of problem its going to be...Ohhhh ohkkk... And about the inductor. Which inductor are you referring too?
The one in the filter section?
I wind my own but all coils are prone to pick up noise. Because its only the high freq that goes trough the inductor it wont saturate that easy so you should be ok...I need to ask you one thing. I didn't actually get the coil type inductor. I got some which looks like resistor. The seller told me that it was fine. Is that ohk?
I'm kinda new to electronics.
If you go to gyraf.dk in the Pultec section you have Steffens diy inductor. How to wind calculate diy inductors its funHow do you wind coils can you please help me
Ohhh ohkkk. Do you think the cores and other parts are hard to get.?If you go to gyraf.dk in the Pultec section you have Steffens diy inductor. How to wind calculate diy inductors its fun
Mu metal is the best or a extra smal enclousureAnd what about the enclosure as you said for shielding the inductor
Is the copper wire and other materials easy to obtain??Mu metal is the best or a extra smal enclousure
No they are everywhere. Look for N48 material RM8 core most eq:s use themAnd what about the enclosure as you said for shielding the inductor
I didn't quite understand you?No they are everywhere. Look for N48 material RM8 core must eq:s use them
Look for enammeled copper wireNo they are everywhere. Look for N48 material RM8 core must eq:s use them
They should be easy to getI didn't quite understand you?
Thank you sir!They should be easy to get
0,1 mm should cover itOhhh ohkkk is there anyother specifics like gauge or size I should I consider
