I've built a stereo pultec, and I have one side
that is 2db off from the other, I have verified
that without the front panel connected, the in
and out looped up that it's still short the two db..
Most of the componet's are exactly the same,
except the 4700u cap on the power board..
Is it realistic to expect them to be closer in volume,
I tried a different set of tubes and checked most of the
resistor values, where would one look for the gain differences?
It's just that if you put this in a mastering chain, it's kind of a pain
to adjust / readjust a A/D for the difference and then it's also slightly
different when the eq is engaged, as opposed to in bypass.
Still quite happy it isn't overheating, but curious now how to get it
spot on.
spot on.
