soapfoot
I've got an H3000 that a friend found in the trash. It powers on and the display is normal--it loads patches, soft keys work. Passes audio in bypass. Input signal does not meter, and doesn't pass audio when engaged.
After much digging, something is pulling the +15v supply rail down, dragging the +5v supply rail with it (both show only a few fractions of a volt at their output). The -15v and -5v rails seem perfect.
Nominally +18v does appear on pin 1 of U7, so the fault appears to be downstream of the regulator.
I've replaced U17 and tantalum C71. The fault still exists, with pins 2 and 3 of U17 showing a short, but would welcome other leads/insights.
For testing, I removed C72 and U20, and the fault persists--this leads me to believe that the +5v portion of the supply is likely fine (is that a fair assumption?). I reinstalled C72 (ceramic) and a fresh 78M05 (both old regulators tested normal once removed from circuit).
My next step was to identify on the schematic all destinations of the +15v supply to look for faults. My preliminary list included 22 ICs and about 15 tantalum caps (I focused on these components as most likely to cause a short).
Some of the ICs are socketed, which made testing without those easy. No result, though--the short persists. I left the unsocketed ones alone for now.
Proceeding to the Tantalum caps, i went through and measured across them in-circuit looking for shorts. Several times (three in particular: C129, C118, C106... schematic excerpts below) showed a short in-circuit, but once removed were verified good (and the short persisted across the empty pads).
As part of basic service, I replaced the large electrolytic filter capacitors, and since I was having issues I replaced the Schottky bridge (CR1) and the 1A bridge rectifier (I knew this was the longest of shots, but since I'm having power issues and I had the parts on hand and it was easy).
On my first examination of the unit, I noticed that a tantalum capacitor in the -15v supply (C74) had blown itself apart. I replaced it before even powering up, and the -15v rail seems absolutely fine, so this is likely unrelated... still, I thought I'd mention it.
I also noticed that at least one of the Murata filters is leaking its dark brown goo all over everything. I cleaned up the board as best I could... should carefully removing these rare/unobtanium parts be my next step? Is there a way to test non-socketed ICs for shorts without removing from circuit? Or is there something else I should try next? Thanks in advance!
