living sounds
The tantalums will likely last much longer. I would go for 35V instead of 25V though.
As far as I remember I think I’ve only encountered shorted Tantalum caps in PSUs rails, but I replaced so many that I might not remember.It should also be noted that there's a big difference between using tantalum caps for power supply decoupling, as in this case, where they can and will fail short, and using them for signal coupling, like in the Neve 1073 et al. Has anyone encountered shorted tants in the latter application? I don't think I have.
Any disadvantage to using aluminum electrolytic caps to replace the tantalums?
plenty of 10uF with 2.5mm lead spacing seem to exist
Here's a sort of a club-and-spear approach: connect a DVM, in continuity mode, across the power rail that is shorted. You should get a fairly low reading, like, a few ohms or less. Then, begin removing components, beginning with the most likely - like, any tantalum capacitor, for instance. When you strike gold, the reading on your DVM will jump to a much higher value.I've got an H3000 that a friend found in the trash. It powers on and the display is normal--it loads patches, soft keys work. Passes audio in bypass. Input signal does not meter, and doesn't pass audio when engaged.
After much digging, something is pulling the +15v supply rail down, dragging the +5v supply rail with it (both show only a few fractions of a volt at their output). The -15v and -5v rails seem perfect.
Nominally +18v does appear on pin 1 of U7, so the fault appears to be downstream of the regulator.
I've replaced U17 and tantalum C71. The fault still exists, with pins 2 and 3 of U17 showing a short, but would welcome other leads/insights.
For testing, I removed C72 and U20, and the fault persists--this leads me to believe that the +5v portion of the supply is likely fine (is that a fair assumption?). I reinstalled C72 (ceramic) and a fresh 78M05 (both old regulators tested normal once removed from circuit).
My next step was to identify on the schematic all destinations of the +15v supply to look for faults. My preliminary list included 22 ICs and about 15 tantalum caps (I focused on these components as most likely to cause a short).
Some of the ICs are socketed, which made testing without those easy. No result, though--the short persists. I left the unsocketed ones alone for now.
Proceeding to the Tantalum caps, i went through and measured across them in-circuit looking for shorts. Several times (three in particular: C129, C118, C106... schematic excerpts below) showed a short in-circuit, but once removed were verified good (and the short persisted across the empty pads).
As part of basic service, I replaced the large electrolytic filter capacitors, and since I was having issues I replaced the Schottky bridge (CR1) and the 1A bridge rectifier (I knew this was the longest of shots, but since I'm having power issues and I had the parts on hand and it was easy).
On my first examination of the unit, I noticed that a tantalum capacitor in the -15v supply (C74) had blown itself apart. I replaced it before even powering up, and the -15v rail seems absolutely fine, so this is likely unrelated... still, I thought I'd mention it.
I also noticed that at least one of the Murata filters is leaking its dark brown goo all over everything. I cleaned up the board as best I could... should carefully removing these rare/unobtanium parts be my next step? Is there a way to test non-socketed ICs for shorts without removing from circuit? Or is there something else I should try next? Thanks in advance!
View attachment 89331View attachment 89332View attachment 89333
Too late. ;-)Here's a sort of a club-and-spear approach: connect a DVM, in continuity mode, across the power rail that is shorted. You should get a fairly low reading, like, a few ohms or less. Then, begin removing components, beginning with the most likely - like, any tantalum capacitor, for instance. When you strike gold, the reading on your DVM will jump to a much higher value.
I've had the same thought recently, i've been servicing lots of old neve stuff and I don't believe I've ever encountered a bad signal path tant. Loads of them in our neve consoles, replaced lots of electrolytics but no issues with tants. great application for them it seems.It should also be noted that there's a big difference between using tantalum caps for power supply decoupling, as in this case, where they can and will fail short, and using them for signal coupling, like in the Neve 1073 et al. Has anyone encountered shorted tants in the latter application? I don't think I have.
