I just had a little adventure with a decomposing AC mains cord in my B3 and some magic bangy poppy sounds. Replacing the cord, I feel like I should add a fuse. I'm thinking inline bus fuse hiding inside the little power/leslie connector box at the bottom, this will retain a stock look, but still easy access to replace a blown fuse.
- Assuming this is the best option (???) - what value fuse? Assume a B3 rockin out with a Leslie and a tone cabinet simultaneously. I feel like a 6 amp slo blow would do the trick. Of course I could also measure current draw with everything cranked up.....hmmmm.
- Should I put fuses on the xformer outputs also? If so, again, what values?
Or just leave it stock like God and Laurens Hammond intended?
Thanks fellas!
Thanks fellas!
