Sure. But i've messed some with it now. I've cut off the part of the pcb with the low voltage part and built the fender tone stack in between the first tube. Changed some coupling caps and tried to sort out the grounding.
The overall tone is a lot better now but it sometimes has a sort of farty distortion. The hum problem is still there and now it also has a bit of oscillation on higher gain settings (about two o clock and above) in the preamp. :-\
Measured the DC resistance of the output transformer and the CT is not really centered.. 107 ohms on one side and 127 on the other. Mybe this is the reason for the power amp hum. There is also some blue glow from the EL84 tubes. But i guess that's normal?
