>>>You grind silver to powder, mix a binder, apply, and you get a LOT of voids, poor conductivity, even with all your diligent work.
Close. Pigments are ground for printing inks. However, conductive inks almost always start with a metal that was chemically precipitated as a very fine power from a metal salt (20-nm to 5-microns). Often this powder is "flaked" by rolling around in an attritor or ball mill with milling media. One key difference with an ink designed for traditional solar applications is the presence of glass powder. The glass is required to etch into the silicon when the silver is fired to aid in current transfer. For back side electrodes, the glass is optional. In general, the four classes of conductive inks are (in historical order):
1. Thick film inks- Contain glass as a binder. Need to be fired above the glass' melting temperature (around 450C). Used for solar, LTCC capacitors, and hybrid ceramic packages. Resistivites ~3x bulk silver are possible.
2. Polymer thick film (PTF) inks- Contains polymer as a binder. The polymer can be cured either thermally or with UV (less common). The shrinking of the polymer during the drying/cure pulls the flakes together to form a continuous conductor. Resistivites of ~10x bulk are possible.
3. Reactive inks - These inks contain a organo-metallic or metalo-organic binder that can thermally decompose into a metal in order to fuse the flake/powder together. Resistivities of ~6x bulk are possible.
4. Reactive nano inks- These inks are made with highly surface active nano particles that can sinter at temperatures as low as 80C. Resistivities of ~2x bulk are possible (limited only by the resulting porosity of the cured ink).
I used to work on type 3 inks, now I work on type 4 inks. You can make a simple low performance type 2 ink by mixing some silver flake/powder with clear nail polish or white glue.
>>>the collecting stipes are blocking light, and "need" to be that wide to carry the miniscule current. He's found a new silver-ink (you got something new?) which can be built-up instead of wide, block less area.
This has been the biggest request from ink manufacturers for silicon based solar. My nano inks are not at all suited for this application. There are other solar technologies of interest though. Check out
Konarka as a starter. OPV manufacturers and researchers are making some very large promises for the future.
>>>(Why can't they extrude silver ink around a hair-fine wire and lay that on the Silicon? The ink just joins the Si surface to the copper. The copper carries the current lengthwise. Too many steps for a product which already costs too much?)
Bingo. A 20 micron stainless steel mesh costs >$10/sq ft. A 20 micron printed silver mesh (if you can do it) costs <$0.05 per square foot.
To be pedantic: we are regulating-out the variations, so it must be an "AC amplifier" in the regulator, and capacitance matters.
But would capacitive coupling between the regulator and the heatsink matter? Short of dropping a glob of silver grease on the PC board, is there any real danger here that I am missing? (not a rhetorical question btw).
>>>You say White costs more than Silver???
Just comparing two similar formulations at retail pricing for 2.5 grams (Artic Silver 5 and Artic Silver Ceramique). I'm sure you could find an industrial bucket of simpler oxide grease for a fraction of the cost of an equivalent silver product.
-Chris
