Hi There,
I have this bass head (had it as an exchange) for some time now, the guy told me "it powers up but it's not working" but that's that, and because i didn't needed it, i never looked to repair , until a friend of mine became interested on it, and so i figured lets sell this thing and get rid of it, good one or not, he will use it more than me....
So first i changed all caps, since this one was made in 1991, so a fresh recapp won't do no harm....
But after powering on this one exhibits a weird issue. You get a loud HUM, and not a Mains hum, louder coming out of it, wether bass plugged in or not.
So i first checked to see if the PSU section is doing ok, and it is, the front panel board is feeded according to this schematic, and Power board section seem to be feeded good as well, all parts on board seem to be doing ok on DMM check, transistors, diodes etc.....
So just for curiosity i checked voltage coming out of the Speaker OUT, and i read more than 40VDC! when speaker is plugged IN, So i tought the Power MOSFET's must be fried, but after checking them on DMM they are doing fine also (these are 2SJ50 and 2SJK135), and all the other transistors on Amp board section are doing fine too on DMM, but maybe they aren't doing fine in situation while DMM makes them look ok?
Problem is that i cant check on board while having this HUM coming out of the speakers, as this will surely fry it pretty quick so....
Anyway, i'm not sure of what can cause this, so just wanted to gather some toughts and suggestions, i'll look deeper into it later today....
Thanks a lot.
Thanks a lot.
