Help Gyraf SSL Compressor
Buddhafred
New member
New Zealand
I've just finished building a Gyraf SSL Compressor. It doesn't seem to compress at all though. It does turn on and off and the makeup gain works. I've checked all voltages I can and everything seems normal except that all three THAT 2181s have +15v at pin 7 and -2.9v at pin 5. Any ideas what could be wrong? Many thanks
..please use (and read!) the dedicated very-very long help thread:
https://groupdiy.com/threads/gssl-help-thread.47/
It would be a real achievement if you had an error that hasn't been had and fixed before in there :)
/Jakob E.
ps: your voltages look alright
To add to what Gyraf says, go the the help thread and use the search function, selecting "this thread". Try searching something like "voltages".
/Jakob E.
Thanks very much. And yes, I found a reply from June 5 2004 that solved the problem. It was that I hadn't jumpered the hpf solder spots near the TL074. So a real simple fix. Long live Gyraf!
