!Help! - identifying this IC
andia
GDIY Supporter
Hi, does anyone know what IC this is. It is in the outputcircuit of a allen&heath AR2412 stagebox for a livedesk. I have found it to be faulty and want to replace it but I cannot find any matching part, if I search for the labeling.
Does anyone have a clue what IC that could be?
Labeling reads: 8080 705F (or 70SF) JRC
Thank you,
andi
    120 KB
Just making a WAG (wild guess) the capacitors between pins 1 and 2, and pins 6 and 7, look like we would expect for feedback capacitors across a typical dual op amp footprint (from output to - input).
That would be consistent with the data sheet you found.
These are not very good ICs. Allen & Heath uses them in new mixers and they often fail. Good replacement is NJM4580.
Did op amp fix the problem?
I am also working on an Allen Heath with a bad channel
Thank you,
andi
Did the new op amp fix the problem?
I am working on a similar Allen Heath mic input issue.
John
yes, there were also some bad resistors right at the input. this is the replacement I used: https://www.mouser.at/c/?q=513-NJM4580E-TE1
I am still having problem with this A&H input. I find several white chip resistors? I don’t have a schematic, so I don’t know the value of these white chip components. I thought they were caps. But they read like resistors.
Can you help with diagnosing this ?
