Learning how to substitute transistors
Don't ever buy NTE. Their specs are all over the place and you never know what you are getting , gave up on that crap in the 70's. Just about any audio fixit forum will tell you the same.
They do have some good stuff like vintage germanium diodes for stomp boxes if you know what your after and dirt cheap at the surplus. Its the cross ref manual that is the problem, every time I do what it says I get a bar b que.
I try to use the KSA and KSC part numbers for repairing Marantz , Sansui etc.
And the ON Semi MJ21193/6 stuff for power.
it looks to me that the Voltage of 2sc1518 2sc1509 are too low... Vcb and Vce for the original are 120V. No?
That is why I don't bother trying to use a substitution guide. I just look at it being equal or greater collector to emitter voltage break over and collector current , check its pin out to see if its the same and call it good. I also change the part in the other channel so it gains the same.
