Silvas
Hello,
I´m checking this mic...it´s working ok, sounds great, all polar patterns OK, sadly, the capsule is a "teflon" CK12....which i succesfully cleaned and the sound improved quite alot. I also flipped the capsule. The problem with this mic is the HPF. When off, no problem, but in the 75 and 150 Hz position, the mic hums quite loud...looking at the schemo, it looks like it´s something related to transistor "tr3", which i checked and it was fine, i even changed it...Any ideas?
Thanks so much !
Thanks so much !
