Dimitree
- Joined
- Jul 26, 2011
- Messages
- 130
Hi everyone,
I'm trying to understand how those two approaches compare when used as ADC front ends.
I extracted the schematic from the datasheets and adapted/modified them (so they may be incorrect after I edited them).
The goal is to provide a balanced line receiver to a 5.6Vpp differential input ADC.
The first approach employs a THAT 1206 line receiver with -6db gain. R8/R9/R20/C4 need to be calculated to drop the signal a little bit more, so that 5.6Vpp output is achieved.
The second approach is using a THAT 1283 (+3dB gain) followed by a resistor attenuator that drops the signal to 2V RMS (about 5.66Vpp).
As far as I understand, THAT 1206 is a better IC than THAT 1283, since CMRR is as high as it can be under impedance mismatch on the differential input.
Other than that, I'm wondering if both are good approaches and if the schematics look correct.
Do I need buffers in front of the THAT 1206? If not, why do I need them in front of the THAT 1283?
thank you!
thank you!
