my house don´t have a earth, it´s 127v with a live and a neutral
For equipment without an earth (also called safety earth, protective earth, safety ground) connection you should make sure that there is no way a simple fault such as cracked wire connection or cracked insulation can cause a power line to contact the chassis. In the US equipment with only line and neutral is called "double insulated" because it is built in a way that any single break of an insulated connection cannot contact the chassis.
So the power transformer is usually mounted on an insulated plate, and plastic insulation is underneath and around all of the power wiring on the AC input side of the power supply, just so that if there is a break somewhere including in the power transformer windings there is no way the chassis can be connected to the 127V power. Note that the power transformers used for such equipment should also be double insulated, so that if the insulation breaks on the primary winding there is no way that the input power can be connected to the output winding.
Xlr pin 1 input is normally connected direct to chassi. So your xlr cabel dont act as an antenns. Cabel screen in a balanced connection is part of chassi ground. In the best case scenario it will be grounded at one end. Audio ground is connected at one point to avoid ground loops…
Note that if the cable shield is only connected at one end between equipment which does not have an earth connection, there could be a very large voltage difference between the two chassis, which will be a common mode voltage to the input stage. With transformer input that should be tolerated, but would not work with direct connected input.
Perhaps a mains isolation transformer , with a centre tapped secondary which you use to establish your own local clean ground might be an option
Not safe. Please do not make suggestions for power wiring modifications without understanding all the safety implications.
Bill Whitlock (MisterCMRR) has a really good presentation, I thought linked from somewhere on this forum, but I could not find that link.
The Central Indiana AES chapter has a link:
https://centralindianaaes.files.wordpress.com/2012/09/indy-aes-2012-seminar-w-notes-v1-0.pdf
Starting on page 22 discusses power distribution. Page 29 has a diagram of an isolated ground and shows why that is completely unsafe in a fault condition.
Starting on page 188 is a more in depth treatment of power line considerations.
The presentation is long, but fortunately includes the notes, not just the slides. It takes a little bit of understanding to understand the entire presentation, but it is like a textbook on audio system grounding. Highly recommended.
