buildafriend
I have a CMOQ-2S output transformer
When I tried to use it, the 312 card did not work. Then I popped (almost typed pooped) in a new CMOQ-2S and the card worked. Through deductive reasoning, I think that this one is broken.
when I was moving I must have smushed a winding.. doh!
http://cinemag.biz/output/PDF/CMOQ-2.pdf
I repaired the leads and I think that they are okay. But inside the transformer might be a different story.
I used to have a signal generator and old tektronics scope, but I broke them.. at least they died in battle.
So, I grabbed my DMM and got cracking. It looks like brown and red don't show continuity.
DCR values:
brown to red - can't get a good reading but my DMM says something like 2M
orange to yellow - 18.4Ohms
green to blue - 18.5ohms
violet to grey - 18.5Ohms
Continuity tests
brown to red - open
orange to yellow - shows continuity
green to blue - shows continuity
violet to grey - shows continuity
Is there any way I can try to repair this?
What methodology is there for testing transformers on a DIY tech bench type budget?
Up next, I'll be probing around a broken EA2622.
DCR values:
Continuity tests
brown to red - open
