I've recently been working on an old Marshall AVT 50. It wasn't working when I got it, but I resoldered the input and it's came back to life. While I got it apart, I figured I'd mess with it a little. I'm planning too
1. Add a 0.68uf cathode bypass capacitor to R29.
2. Replace R32 with a 100k resistor.
These two swaps would increase gain from the 12AX7 .
I've also picked up all the Dijon caps from mojotone to replace all the caps in the signal Path. Including the few electrolytics that I need.
There is some clipping LED's labeled LED 2, LED 3, LED 5 & LED 6. I was wondering, would it be ok to remove LED 2&3 and replace with jumpers and then replace LED 6 with 1N4007 diode. Then, I could replace LED 5 with wires going to a On/off/on toggle with a different diode arrangement on the switch?
My main question, would be could I remove LED 2 & LED and replace with jumpers to get rid of some the harsh distortion from the clipping circuit?
For the record, I am aware amps contain high voltage. I am safe, and take all precautions while working inside the amp. I have provided a schematic of the preamp section for reference
