imloggedin
Hey guys. I have a Peavey Tube Sweetener and I would like to use it on my 2bus. The problem is that it has a horrible low pass built in with a tone control. I would like to bypass the tone control completely. I have attached a schematic of the input section of the first channel. If i put a jumper between the red arrows that i highlighted, do you think that will be enough to test bypass the tone "CONTOUR" circuit? Maybe they have a lowpass somewhere else in the circuit also? I don't see it, but I'm not good at EQ's. Any help is appreciated! I really want to use this thing.
