imloggedin
bernbrue said:This is getting ridiculous. Sorry, but I had to edit my post.
regards
Bernd
Oh my bad you said VR1A. I just saw VR1
regards
Bernd
bernbrue said:Hi,
in response to your pm. There is not much left then.
regards
Bernd
No HPF... loses bass from pole with C2imloggedin said:bernbrue said:Hi,
regards
Bernd
I bypassed everything like was suggested by Bernbrue. Then I put a 100k pot in the mix. One way I shunted it to ground to bleed off the signal (it worked as volume).. the other way I used it as a resistor in series with the signal, and it did nothing when turning it. I'm pretty sure as John said that bleeding signal to ground causes the LPF.
When I turn down any of the volume knobs (thus bleeding more to ground) the LPF starts happening. When I turn them up, the LPF goes away, but then the signal distorts (tubes driven hard). Same applies to VR1A and VR3. I don't know of any other way to attenuate signal without using ground. John, I believe you suggested using R1 as a pad, but I don't know if that can be variable on a pot cause its 275v? UGHHH
emrr said:Did you bypass V1A like I mentioned? That'll definitely turn down the gain. Any time you turn down a pot in a high impedance circuit, even more with high mu tubes, you start losing high frequencies. And R17?
emrr said:Ok, you've misunderstood twice now. V1A, the first 12AX7 stage, not VR1A the pot. Lose it. VR1A/3 to C7. Disconnect the stuff in between those two points from those two points. Gain will go down.
That after trying the R17 strap-out first, it may help the high freq situation, may not.
